Running the truck without EGT sensor??
Hypothetically speaking.... if a friend of mine were to do the DPF/DOC delete install... and they cant get the rear sensor out... can they still run the truck till they get a new one to put in the pipe?? will it throw a code or do any kind of damage?
I couldn't get mine out so i ran it like that for a day before i got a new one put in and all it did was make the truck be in high idle all the time it didn't throw a code though.Hope this helps.
Depends on which tuner they are using. With anything other than the H&S, you have to have the sensors connected or else the truck will eventually die and will not crank.
