egr delete/ wastegate?
I wanted to know if anyone had the egr delete/wastegate installed on their truck? how hard is it to install?
Pretty difficult really requires cab removal to be done correctly, Dirty Diesel is working on a setup that will not require cab removal and will be more reasonably priced as well over the Elite version. We will be stocking these as soon as they become available so keep your eyes peeled!
Elite is $1200 I believe they are shooting for $800 or so. They have had some issues with getting the parts machined in a cost effective way and I actually have some of the parts being quoted locally to see what we can do in the states.
if i remember correctly, the wastegate feature used some stock components, or was that incorrect?
Both will use basically the same parts, the EDE kit ties directly onto the passenger side uppipe and reroute the EGR passage into the downpipe. The Dirty diesel is going to use the current EGR crossover tube that feeds the horizontal cooler and then dump under the truck into the delete pipe.
I am in the market for one of these right away. My head gaskets are almost possotively blown and when the cab comes off I want to do the wastegate and egr delete. Are there any directions or photos that show the install of either kit?
Does anyone know if the dirty deisel kit will be able to be removed if it needed to be taken off for any reason? I know you cant really do that with the EDE kit since it has to be welded into the downpipe.
I will call Rob and get back to you.........
