Spartan gauges
Can someone tell me where I can find a list that tells me what all the read outs on my spartan gauges mean and parameters to look at staying within. Thanks
EGRTA – Pre Turbo EGT
High Limit 2000 High Warning 1600 EOT – Engine Oil Temp High Limit 300 High Warning 230 ECT – Engine Coolant Temp High Limit 275 High Warning 225 FRP – Fuel Rail Pressure High Limit 30000 High Warning 27500 Low Warning 4500 FRT – Fuel Rail Temp High Limit 200 High Warning 140 TFT – Transmission Fluid Temp High Limit 275 High Warning 220 MGP – Manifold Gauge Pressure Max Depends on you High Warning Same as above |
Wow thats service, and I'll assume you had a smile on. Thanks
I would have beat him to it if I hadn't been on the damn phone with Mick
And we have also changed a few things on the config file that now goes out with the DashDAQ's. On the fuel rail pressure we changed the high warning to 30,000 to match with the high limit. On the low limit, we changed it to 0 zero so it's not alarming when you turn the key on before starting the engine......
mine doesnt warn me wwhen i start my truck and its nto set at 0
Mine does....might be due to my Air Dog fuel pump though. With the key turned over and the truck not cranked I will see between 20 psi and 200 psi of rail pressure.
