DD update - Ford Powerstroke Diesel Forum
Old 01-10-2010, 08:06 AM
DD update
I received my files from Spartan. Followed all directions to do the update & unzip the new tuning files. It unzips all tuning files good but when it gets to the 250HP_2 file says the following. Can i still load a tune file into truck. Guess it unzipped all files except the 250HP_2 tune. What can i do to get all tunes unzipped. Buy a new bigger SD card????
Error writing to Tuning files\250HP_2.gtf. Possible cause. disk full
Old 01-10-2010, 08:23 AM
How big is your SD card? The zipped size is 128MB, so unzipped, it is probably a little bigger. If you have a 256MB card, you should be fine.
Old 01-10-2010, 08:28 AM
Its the one that came with the DashDaq. So its 256mb. I tried to load the new tune files but cant find them to load on the DD . What am i doing wrong...
Old 01-10-2010, 08:45 AM
how much free space is there on the card? I would un-zip the files to a local directory on your hard drive, and then copy them to the card in the appropriate folders.
If you copied a 128mb file to the card, then unzipped it, it will at least need another 128mb to unzip, and probably a lot more than that. Basically 128+128 (or more) is bigger than your card (256MB). You can either unzip the files to your hard drive and copy them, or get a bigger card and to it exactly the way the instructions say..
