310 tcm tune
I finally got the tcm installed and loaded the 310 tcm tune then did the relearn for the trans it runs real nicve and shifts like a dream. idrove with it around 200 miles so far with no touchy pedal issues or surging at all and the converter locks up like clock work @ 45mph. during the relearn process i did see 1700 egt's for a second and boost seen 51.6 also the fuel pressure alert went off around 28,000psi. the question is does this all seem in line with other 310 user's #'s? when i see the alerts go off i back off the pedal a bit so i can't get a great feel for how it runs not that i run it hard just want to feel it out so i know plus it's something new!
Chris |
seems pretty normal to me.
All sounds normal to me also.
Sounds good!
None of the #'s struck me as being way to high i just don't want to stay on the pedal and have the boost climb to high i guess it will top out somewhere but where is the question? i just don't want to pop anything if i can help it.
Chris |
With the production 310 TCM file that I ran, I would see between 48-50 psi of boost max. That was the very first production 310 TCM file though. I think it has been revised slightly. I doubt boost was revised though.
I think i saw the highest of 52 psi but Mick advised of setting the DD @ 48 hw and 52 hl so i guess it's around it's peak.
Chris |
I have seen 52psi boost from mine, and only saw it when I did the relearn process.
not on the 310 tcm but I have seen over 55 in my truck once or twice UNLOADED. Lets just say i was very lucky nothing blew.
