P006B - Ford Powerstroke Diesel Forum
Old 01-02-2010, 07:42 PM
P006B
I got this code this evening P006B MAP/Exhaust Pressure Correlation. This is the first time I have seen this code and only come up with 2 posts when I do a search. I have searched elsewhere and still don't have an answer. I am running the 210 tune, truck had been running for 15 min or so to warm up. Temp on the display showed 0 to 1* anyone have more information on this code? Truck seemed to act normal for the cold weather, didn't notice any driveability issues.
Thanks, Jordan
Old 01-02-2010, 07:50 PM
I got that code once or twice, then I began getting another code (can't remember it) instead of that one. Replaced my EBP sensor and it went away. See if your exhaust note sounds different at idle....like no hiss, just a deep sound that actually sound really good.
Old 01-02-2010, 08:03 PM
If it gets rid of the hiss I wish mine would go bad LOL.
Old 01-02-2010, 08:05 PM
It hurts performance. Makes the truck laggy
Old 01-02-2010, 08:17 PM
The exhaust still has a hiss to it like a blow dryer if thats what you mean.
Old 01-02-2010, 08:20 PM
Yours may be a blow dryer....mine is a F250 attack Jet.
Old 01-02-2010, 08:43 PM
Ha ha I bet you were the little kid that had a lowrider micromachine and told everyone you had a monster truck too. That was a good one though, it made me laugh and I freak out everytime I get a code so thanks for your help.
Old 01-03-2010, 06:27 AM
Thanks, Jordan
Either your MAP sensor or your exhaust backpressure sensor has gone bad. Probably the EBP, odds are. I don't have a DashDaq, but it seems like you could view the output from both of them when you key on, before you start the truck. On what will be a cold start, one of them will probably be different than standard atmospheric pressure where you live. That's the bad one.
Old 01-03-2010, 04:05 PM
This morning I had the key on engine off and EP MAP and BARO where all with in .5 psi of each other. Once the truck was started EP was 17.6 MAP 14.6 and BARO 14. The code did not come up this time. Are these numbers close enough to not throw the code or how much of a difference do I need to be looking for to know for sure that it is the EP sensor?
Old 01-03-2010, 06:02 PM
Actually I was the kid that didn't have any toys. So I worked hard and got a good job and appreciate everything I have. I'm light hearted and try to make people laugh and enjoy life as much as I can because I know what its like to have your life suck. I'm sorry I attempted humor in your thread in which you where trying to get answers to your problem. Maybe if you get those answers you can relax and enjoy life because that code may just be the end of you.
Here's a bump for ya!
