2008 f250 6.4 intake and programmer help? - Ford Powerstroke Diesel Forum
post #1 of 78 Old 12-03-2009, 02:04 PM Thread Starter
abruno25's Avatar
hello, i have a 2008 i'm interested in putting in a intake and programmer, so from the readings i see that s&b wont give to many if any codes... now any sugestions on programmer for a 08 f250 6.4? also is it possible to change programs back to stock incase i have to bring it in to a dealer?
abruno25 is offline
post #2 of 78 Old 12-03-2009, 02:12 PM
08stroker250's Avatar
I recommend Spartan, S&B, and the AFE downpipe back exhaust. All of this can be found at Cobb's Diesel Performance.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 78 Old 12-03-2009, 02:28 PM
Rudy's diesel performance's Avatar
Yes, you can easily go back to the stock settings with whichever tuner you choose. I would recommend either the Spartan or SCT Livewire. We have both in stock along with S&B intakes and any style exhaust system you would like. Check out DPF Delete Kits for Ford Powerstroke 6.4 & GM Duramax LMM. Let us know if we can help in any way!
Sales @ Rudy's Diesel Performance
*CONTACT US FOR SPECIAL PACKAGE DEALS ON SPARTAN, SCT AND H&S PERFORMANCE DPF/CAT DELETE KITS*
(919) 383-9300 OR Toll-Free # 1-866-757-6537
Rudy's diesel performance is offline
post #4 of 78 Old 12-03-2009, 03:12 PM Thread Starter
abruno25's Avatar
what has to be done when you put the dpf delete kit? does this void any type of factory warranty? will the car give me any engine codes when you do that so its not cleaning the exhaust filter? kinda lost of what to do with the dpf...
abruno25 is offline
post #5 of 78 Old 12-03-2009, 04:11 PM
When you remove the DPF, you run a tuner (Spartan, H&S, SCT), DPF delete exhaust, and if you choose, a cold air intake. The tuner will allow for the removal of the DPF without any codes. If you did this, you would need to put everything back to stock before going to the dealership. MOST dealerships are not modification friendly, so they would void your warranty for removing the DPF and tuning the truck. Most dealerships don't like cold air intakes either. You can get around the whole warranty issue....it just takes a little work on your part. The fuel mileage and power are worth it in my opinion though.
Jeff Dodd
post #6 of 78 Old 12-04-2009, 03:42 AM Thread Starter
abruno25's Avatar
ok sounds good, i live in p.a and i think its different state to state but with out that dpf will it pass a state inspection for emissions?
abruno25 is offline
post #7 of 78 Old 12-04-2009, 05:11 AM
Visual inspection, no. Depending on the actual emissions testing, it might pass with a stock power level tune with the DPF off.
Jeff Dodd
post #8 of 78 Old 12-04-2009, 05:54 AM Thread Starter
abruno25's Avatar
ok sounds good, what about a dpf/cat delete kit with a sparta programmer, will that take care of all engine codes? anything more tech. in volved with the instal of the dpf/cat delete then a regular dpf kit? thanks for all the help
abruno25 is offline
post #9 of 78 Old 12-04-2009, 06:39 AM
That would be everything you need right there. Spartan tuner with DPF/CAT Delete pipe, you would not need to do anything else.
post #10 of 78 Old 12-04-2009, 06:45 AM
cbenn's Avatar
Quoted: 3 Post(s)
I purchased everything from Aaron, if you have questions when ordering he will take the time and explain, if you have to leave a message he will call you back within minutes, he also has great prices.
2017 F350 Lariat Dually
Airlift air bags W/ Wireless remote.
2.5 Icon coil springs
PMF adjustable track-bar
PMF dual steering stabilizer
cbenn is offline
