Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
Old 11-04-2009, 02:26 PM
Yalro6 Yalro6 is offline
Dashdaq Monitoring Question
Im hoping to get an intake soon and upgrade from the 210 to the 275, but when I do this what temps are ideal to monitor?
Old 11-04-2009, 02:30 PM
08stroker250 08stroker250 is offline
Cobb's Diesel Performance
What do you monitor now?
Old 11-04-2009, 04:42 PM
cj performance cj performance is offline
Send a message via AIM to cj performance
im curious aswell.. i put mine on a week ago and havent even looked at any of the monitoring stuff. what do we set alerts at etc? whats best to watch for?
Old 11-04-2009, 08:52 PM
atm i dont monitor anything. just run the 210 and check the filter every know and then since its stock.
Old 11-04-2009, 09:06 PM
I would monitor EGRTA (exhaust temp), Trans Temp, Coolant Temp, Oil Temp, Fuel Rail Pressure, and Manifold Gauge Pressure (boost).
Old 11-05-2009, 01:31 AM
and setting an alert on those..what should they be at? Monitoring them wont do any good unless we know its limits!!!
Old 11-05-2009, 04:03 AM
EvilTwins EvilTwins is offline
A Wise man once wrote ......
DashDAQ Gauge Temp Settings - Spartan Diesel Tech Support Forums
And all rejoyced
Old 11-05-2009, 04:44 AM
ol38y ol38y is offline
By monitoring 6 items I'm assuming you are using the digital readout across the bottom. If so, do you think I just need to download the rest of the files Mick sent me? At this time I can't get the lower digital readouts to display.
Old 11-05-2009, 06:26 AM
Dusten Dusten is offline
Send a message via MSN to Dusten
yes.
MODS: can we get a sticky of some sort with links to how to load the config file on the spartan, and links to all the skins for the spartan? There are enough threads about what to monitor and what alarms to set, that it would be nice.
Old 11-05-2009, 06:27 AM
also, on a second note. when you are looking at a display, like the "spartan" theme if you scroll left and right some of the displays show up to 9 or 10 things at the same time.
