Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
Old 11-03-2009, 04:29 PM
FX4STROKER FX4STROKER is offline
COTTONWOOD CREEK RANCH
Whats the thread and size for the pressure senson on dpf pipe
Hey guys today I helped install a dpf delete pipe on the owners truck of the local sporting clay place (trading a membership for install) and I couldnt get the pressure sensor bung out of the dpf. I had him buy the 3 egt sensors but not a new pressure sensor bung. I know I could buy one from ford or cobbs but was wanting to get in finished first thing in the AM. Does any one know what thread and size that deal is so I can just buy a bolt from napa and make one real quick. Thanks
Colt
Old 11-03-2009, 06:25 PM
bump! Come on guys! I know one of yall knows!
Old 11-03-2009, 07:04 PM
geabis geabis is offline
i got mine from Cobb. but it looks like a spark plug thread. like around 1/2 fine or 12mm with a taper seat. but thats just a guess.
but i'll bump you up top again
Old 11-03-2009, 07:06 PM
btw. it will run with out it connected to the exhaust (if using spartan) without a problem. you can wire tie it to the frame untill you get the part ordered and in then put it together at a later time.
Old 11-03-2009, 08:17 PM
jayhawkintx jayhawkintx is offline
I do have a question regarding the sensors in the DPF/DOC deletes. Are they really needed if you have a Spartan? Why do they have the spots for them in the delete pipes if you really dont need them?
Thanks.
Old 11-03-2009, 08:20 PM
There are 3 egt sensors and one pressure sensor. I could be wrong but I think the 3 egt sensors help with tuning. Im not sure about the pressure sensor and If i could just block it off that would be great. It would be nice to just un hook the sensor and put a plug in the dpf pipe.
Old 11-03-2009, 08:22 PM
08stroker250 08stroker250 is offline
Cobb's Diesel Performance
Dustin Woodhouse (dzchey21) plugged his pressure sensor bung up with something. He mentioned it in a thread either on here or PSN in the last few days.
Old 11-03-2009, 08:29 PM
i think the spartan and the emc still needs to see the sensor. it just doesn't use it for pressure readings once the truck is tuned (it can read the barometric pressure) so it will still need to be plugged in.
Old 11-04-2009, 03:24 PM
Blk350on20s Blk350on20s is offline
I believe its 1/4" npt. Had to do the same for mine but it was a while ago.
Old 11-04-2009, 03:50 PM
benbou00 benbou00 is offline
Yes it is 1/4" npt I have one in mine.
