Good evening!
Its been a while since I have Posted. I need HELP!! I Have a H&S Black Max and last night the screen went out on me. The unit still works just no screen :doh:. After having it for 7 years. I have reorder a mini this evening. but my question is can someone give me step by step instructions on returning the truck back to stock? Or if you have any other suggestions, I'm open. Thanks for your help
Hmm that's a tough one.....you may have to go to Ford and have truck flashed with as built data and then load your mini.....just make sure mini is an off road tuner if you're deleted.
Thanks for the reply. I thought about that. Was hoping someone with a H&S could give me a step by run through of returning it to stock. The unit still works. Just don't have a screen.
I have cracked the screen on my mini max is there anyone around who can fix the screen I can still see part of it
I don't have the money for a new one I bought my back before the EPA shut H&S down
To touch back on my problem with the H&S Black max. I just hooked the mini max up and loaded it. Done problem solved. There was no need to return it back to shock before install.
I have run across a guy on facebook that has a minimax that we believe to be vinlocked (hes checking to make sure) for the right money would it be hard to pop it open and switch screens in them
Pop open yours and check the model number on the screen and then do a search. I am sure you will find a replacement from China. It is worth a try. Where i work we do it all the time on handheld scanners.
Sent from my LGMS631 using Tapatalk
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
