P1103 code - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-21-2009, 07:16 PM Thread Starter
benbou00's Avatar
P1103 code
Well i made it out to the track again tonight and i got the P1103 code mass air flow sensor higher than normal once. What could be the cause of this?
benbou00 is offline
post #2 of 7 Old 10-21-2009, 07:37 PM
cambo's Avatar
probably because of the afe intake , that was what I was told about mine
cambo is offline
post #3 of 7 Old 10-21-2009, 09:34 PM
08stroker250's Avatar
P1103 - This error occurs when the measured value of mass air flow is higher than a threshold value for a predetermined period of time.
According to what I have it could be wiring, MAF assembly, or the PCM
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #4 of 7 Old 10-22-2009, 12:22 AM
powerstroke586's Avatar
my MAF went bad when my truck was stock it would throw an engine code and go into limp mode and made it seem like my turbos wouldnt spool.
2008 F-350 cc, short bed, Dark pearl blue
2" leveling kit w/ 35" Mud Grapplers on 20" Jesse James Widow wheels.
Spartan tuned with the 310 tune
4" Flo Pro DP back exhaust w/6" tip
Ceramic coated DP
AFE stage 2 Intake
Autometer cobalt gauges pyro, boost, trans.
Pro Comp traction bars
WOP Egr delete
Dirty Diesel CAC pipe.
Suncoast full race trans
A-1 technologies studs.
powerstroke586 is offline
post #5 of 7 Old 10-22-2009, 04:02 AM
NuttyProfessor's Avatar
The AFE and the lack of tuning for it will cause that code. What altitude are you at?
NuttyProfessor is offline
post #6 of 7 Old 10-22-2009, 07:51 AM
hmmmm, I have fixed that code for a couple other guys, and will gladly fix it for you. Depending on Temperature, tuning, elevation, and brand of air intake it can throw this code.
Give me til this afternoon, i'll have an update on the web!
Bentley
H&S Tech is offline
post #7 of 7 Old 10-22-2009, 11:04 AM Thread Starter
benbou00's Avatar
Bentley
Thanks....
benbou00 is offline
