Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
Old 10-03-2009, 11:55 AM
mmfruitveg mmfruitveg is offline
DPf delete
In the humble opionon of this forum, how is the dpf delete accomplished?,and if it is a pipe removal, who sells the best replacement pipe?......I guess there is no way to get rid of the regen issue without doing some cutting?....No tuner will delete it?......getting a new truck next week.....need to start to gather toys...Mike
Old 10-03-2009, 12:24 PM
Rollin Smoke Diesel Rollin Smoke Diesel is offline
You can remove the DPF and replace it with a delete pipe. Your best bet is too chose from one of the few tuners that will disable the DPF.
James
RSD
Old 10-03-2009, 04:49 PM
Dusten Dusten is offline
Send a message via MSN to Dusten
the dpf delete is accomplished 1 of 3 ways. you buy a delete pipe from any of our sites sponsors(cobbs, rudy, just to name a few) then you install the pipe. This 2 of the ways, you do either a dpf delete or a dpc/doc delete. the latter being easier. The third option is just whether you want stock exhaust or not after the delete.
Cutting? Pretty much any tuner for the 6.4 can rid you of the regen. the sct is a good budget way. The edge doesn't tune the trans and can be a sketchy option. Spartan is widely regarded as the bet option.
Old 10-03-2009, 07:26 PM
elibenson elibenson is offline
DPF deletes are very popular. There is a number of vendors on here that sell good delete pipes. There is also vendors and manufacturers on here that sell tuning/tuners that will disable the regen process once you get a pipe installed. I'm sure they will be flocking in here any minute with a offer..
Cobbs Diesel is a good choice. Rudy's Diesel Performance also.. Great people, all of them.
Old 10-04-2009, 04:58 PM
bhamm557 bhamm557 is offline
Send a message via AIM to bhamm557
they also have a DPF/R pipe which u will not need a tuner.. It will just get rid of your regen issues. Never tried it but i know its out there.
Old 10-04-2009, 06:13 PM
there have been a lot of issues with it for the 6.4
Old 10-04-2009, 06:35 PM
I knew of this device when I made my post, but I also know that it is not 100% reliable, so I didn't recommend it. I don't know of any person that still runs one of these devices.
Old 10-04-2009, 07:26 PM
I personally dont know of anybody running this either. Just putting options out there. Never heard good or bad things from the dpf/r pipe..
Personally i would just go with spartan and do it right. Im loving it.
Old 10-05-2009, 04:14 AM
greasltn greasltn is offline
DPF/DOC is the easiest way to do the delete, you dont have to unbolt ungodly amounts of bolts and worry about gaskets. The spartan tuner is the best for these trucks, but the SCT will work if you are on budget.
Old 10-05-2009, 12:23 PM
powerstroker67 powerstroker67 is offline
Have to agree, the one piece CAT/DPF swap is the easiest way to do it. Spartan would be my suggestion on tuning also. Stay away for the DPF-R stuff, nothing but problems on the 6.4's. We are a distributor for Spartan and manufacture the pipes, from DPF only to full CAT/DPF,downpipes, and complete systems. Let Aaron or I know if we can help you. Thanks Sean
