40 hp tune trouble... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-01-2009, 01:04 PM Thread Starter
KTMotoRider1's Avatar
Been runnin my spartan 40 lately and Ive encountered a problem...When I floor it from a dead stop it takes off really slow and then shifts into second and takes off like normal...I dont think it the tranny because the TC slip is normal and I dont feel any slip or shutter.. but I havnt ruled it out. Its been kinda off and on to last night it was it would do it and this morning it was fine but now its doing it again..no codes either. Any ideas? when its in D1 it just feels like it has no power...
Ford F250 6.4 CC/SB, Spartan 350 w/TCM, Mag-Hytec deep pan, Flo-Pro 5 inch Exhaust, AFE stage 2 with ProDRy, 2.5 Readylift, ZEX Nitrous single stage, BD CAC pipe, ATS 5-star converter, elite egr delete/wastegate, ts mp-8 stacked, Procomp traction bars, locker, CFM plenum, ARP studs. Innovative tunes and Suncoast on the way!
KTMotoRider1 is offline
post #2 of 7 Old 10-01-2009, 02:24 PM
08stroker250's Avatar
How long is it slow for? Is it just a second or 2, or it is it longer than that?
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 7 Old 10-01-2009, 02:26 PM
AED F250's Avatar
It has no power because its a 40 hp tune.
I didn't know spartan had a 40 hp tune...lol
2008 FX4
Fabtech 8 w/37's
Intake, delete pipe/exhaust, Spartan/KEM tuning
567 RWHP/1128 RWTQ
13.3 @ 103.9 MPH
AED F250 is offline
post #4 of 7 Old 10-01-2009, 02:27 PM
Stock No DPF, 40, 75, 120, 150, 175, 210, 250, 275, and 310
Jeff Dodd
post #5 of 7 Old 10-01-2009, 07:58 PM
How long have you been running it? Sometimes it helps for the higher tunes to be re-loaded from time to time. It seems that the adaptive fueling strategy gets a little lazy with age. Reloading the tune makes it reset the computer, and will yield more power.
I don't know if the same holds true for the 40hp tune.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #6 of 7 Old 10-01-2009, 10:11 PM Thread Starter
Well I loaded the 150 tune and the thing seems perfectly normal. The 150 feels like a fricken rocket ship compared to the 40 let alone the 310 lol. No it was slow for the entire 1st gear! then it would shift and take off normally. It would do it off and on to sometimes it would be weak and other times it would chirp the tires pretty good. is it possible since I only had the tune loaded for like a day that it had something to do with the tranny learning process??
post #7 of 7 Old 10-01-2009, 11:06 PM
SpartanDieselTech's Avatar
The 40HP tune has almost all low-end torque limitation left in place just like a stock file- expect lag to be very similar to stock. What you are seeing is normal. Bump up to the 75HP and it should be quite a bit better.
Matt Geouge
SpartanDieselTech is offline
