Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
  #11 (permalink)
Old 10-02-2009, 06:05 PM
08stroker250 08stroker250 is offline
Cobb's Diesel Performance
I was not aware of that. Good thing you pointed that out. Thanks man!
  #12 (permalink)
Old 10-02-2009, 06:17 PM
FX4STROKER FX4STROKER is offline
COTTONWOOD CREEK RANCH
I didnt know that either! When I had my 350 I looked at a set of used ones and that never crossed my mind. What all is diff on a 350 to a 450? I know gears and wheels but wonder what all is diff.
  #13 (permalink)
Old 10-02-2009, 07:28 PM
geabis geabis is offline
just checked the specs on the website. i knew my 450 had 10 studs but wasnt sure if it came with my 14500# option. but the site confirms that the 450 has 10 and 350 has 8
maybe a set of adapters? but Ive always been afraid of using adapter for fear of compromising the capacity of the truck and losing wheels at the studs during hauling something heavy
  #14 (permalink)
Old 10-02-2009, 07:43 PM
aside from the greater gvw. the front end has a wider track, it only comes with the 6.4, crew cab and long bed. a visibly larger rear end and ring gear (the rear looks like a medium duty trucks rearend). available lower gear ratios down to 4.88. and when i test drove the 350 vs the 450 the 450 had a harsher ride. and the 350 road much like my 3500 GMC that i traded. but i think this is due to the plow package that my 450 has and the 350 didn't. and it feels like its about 800# heavier than the 350 that i test drove. maybe even heavier than that bc there was a difference in rearend ratios between the two (id have to check back to the specs on the web site to confirm)
off the top of my head thats all i can remember from when i was weighing it out before purchasing.
BTW i got the 450 bc i liked the wheels better than the 350. it was really the deciding factor, that and the front fender flairs look really neat.
Bill
  #15 (permalink)
Old 10-05-2009, 06:08 AM
Slick02 Slick02 is offline
On my 06 dually, I used a set of 19.5 Brentz Classic's (direct fit 19.5x6.75) with Michelin xde+2 265/70r19.5 tires, no spacers/adaptors etc, and had 3/8" of clearance between the rear wheels/tires and used a 2 1/2" leveling kit on the front
  #16 (permalink)
Old 10-05-2009, 07:06 AM
eastern eastern is offline
I installed a pair of 22.5 on my F350 . Had to pull back the fender liners in the front and shift the box back to get even spacing. did no suspension changes. I tow my 36' 5th wheel camper with no problems. Would I do it again prob. not. It looks awsome but is ALOT of weight added to the truck.Got them from american force.
  #17 (permalink)
Old 10-05-2009, 07:47 AM
if you are loading heavy or towing heavy. you may want a little more than 3/8" bc you may but the side walls and see some wear on them. this would be bad bc it will lead to a side wall blow out
