exhaust sensor question - Ford Powerstroke Diesel Forum
Old 09-27-2009, 06:36 AM
Im working on putting together a custom exhaust with a cutout that will dump right under the passengers side front tire. What im wondering is if I do that will it throw a code or make the truck run bad when the cut out is open. It will be before the pressure sensor and before one or two of the temp sensors.
Old 09-27-2009, 06:58 AM
It shouldn't the pressure sensor doesn't even have to be in the exhaust stream.
Old 09-27-2009, 10:44 AM
It will run fine. If you run the cut-out for more than a few hundred miles you may get some EGT codes. They will not affect performance , and will clear easily. I doubt you will even see them though.
