Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
Old 09-25-2009, 03:06 PM
Dusten Dusten is offline
Send a message via MSN to Dusten
dashdaq in the ashtray
I have seen some mounts down by the ashtray area(by your knee) how are you mounting it there?
Old 09-25-2009, 03:34 PM
AED F250 AED F250 is offline
It is REALLY easy. Just remove the ash tray assembly, install the windshield mount that comes with the DD and then snake it into the hole where the ash tray was. You kinda have to play with it a little, but once you get it where you want it tighten up the ball socket on the mount and your done.
I have done this on a few trucks now and it works great. Every now and then you may smack it had enough to move the pivot ball, but its easily moved back.
IMO, that is where the DD was meant to go.
Old 09-25-2009, 03:55 PM
im assuming you're just wedging it in there?
Old 09-25-2009, 04:24 PM
OOWeaver68 OOWeaver68 is offline
i used the arm on the mount only, not the suction part, run a zip tie through the hole of it and around the metal support, and tighten it up, its worked great for me, i can unscrew the DD from the arm and use it somewhere else and put it back with no problems
Old 09-25-2009, 06:21 PM
well i left the suction cup on and used some 3m tape to stick it to the surface i wanted, and used a few zip ties for good measure
Old 09-26-2009, 10:03 AM
CobbsDieselPerformance CobbsDieselPerformance is offline
Looks great!
Old 09-26-2009, 10:44 AM
Good job!
Old 09-26-2009, 12:24 PM
winchester33 winchester33 is offline
thats how i have mine mounted. i might get an edge pod and put it on the dash. i don't like the suction cup on the windshield... it sticks out too much
Old 09-26-2009, 02:23 PM
Hanging_Heels Hanging_Heels is offline
What does the Dash Daqs come with the option of different colors now? I thought they were all that silver/gray looking? I like the black alot!
Old 09-26-2009, 02:59 PM
this is the new version of the dashdaq
