Spartan TCM
does the Spartan TCM work with all the tunes. i just purchased one with the 310 tune and am worried about how streetable the 310 is. and am wondering if i will have to run the stock tcm with the lower hp tunes or does the Spartan TCM work on all the tunes (dpf, no dpf off road. as well as the 275 and 310)
You can get other tunes for the TCM, not just the 310 tune. Its $100 for the 275 and 310 tune together, and then you can get 3 more tunes for $100. That would be any of the lower tunes.
am i to understand there are tunes for the tcm and tunes for the truck? two separate entities. bc i bought the 310 race tune upgrade with the tcm. do i still need to purchase the the actual race tune for the spartan tuner/engine? i guess i should have added that i also purchase the spartan console and a downpipe back exhaust at the same time(so i should have the pre loaded tunes)
i have a wait for the tcm anyway bc they are on backorder. but wanted to get a game plan together for next weekend. so i can get everything that isnt on backorder installed and still have a working truck |
There are seperate tunes for the Spartan TCM and factory ECM. The TCM is blank when you get it, so there has to be tunes written for it to work. Normal tunes are written for your factory TCM and factory ECM. Make sense?
the tune that you purchase with the TCM is just for the TCM then?
if so, let John know I'll be calling him in the morning to purchase the race tunes for the ECM and some select tunes for the TCM (i may hold off on the tcm tunes till i get the tuner installed and know better on what tunes i want to run). thanks for you help Jeff, Bill |
Glad I could help Bill |
the tune that I purchased for an additional $100 at the time I purchase the Spartan TCM, doesn't include the race tunes for the ECM, correct? i didnt purchase the race tunes with the Spartan console for the additional upgrade of $375, so i still need to purchase the race tunes for my ECM, correct? thanks so much for your quick Replies |
No, all tunes are written for the ECM. Its just the Spartan TCM is different from the factory TCM. You dont have to worry about the ECM with any of the tunes. You just have to know which tune is for which TCM. It sounds like the 310 tune that you ordered is most likely for the Spartan TCM you ordered. Nothing else needs to be done. You just can't run that 310 tune with the TCM that is on the truck now since it is made for the Spartan TCM.
Cool, I got it now.
thanks |
