Just a heads up for those about to install Spartan's TCM (instructions) - Ford Powerstroke Diesel Forum
Old 09-16-2009, 06:59 PM
I wanna go fast!
If you can't seem to get your hands on the 2 13MM bolts and get them loose on the frame mount bracket, you can use a 8 mm flex rachet wrench and take the 2 bolts out that hold the TCM to the mounting bracket instead
Thanks for the tip Matt
Old 09-16-2009, 07:03 PM
Yup, very easy way of doing it, I can swap mine in and out In a matter of minutes!
Old 09-16-2009, 08:32 PM
I'm not clear on why Ford sells it with a bracket too. It makes no sense at all. I bought a Horizontal Fuel Conditioning Module (pump/filter thingy) for my 2004 E450 and it came with a big black bracket much like the TCM has, and I don't have a clue why. It was way easier to just unbolt the HFCM than it was to remove the bracket/HFCM.
I took one look at the new TCM, and I had already decided that I was going to cheat and do it the way that was described here.
