spartan and EGTs
Ok well ive done a lot of reading on the spartan and i am pretty much sold on it. but ive got two trucks i know you can do more than one truck with one tuner but do i really need to use the monitor on either truck because i dont really want to have to have it on my dash a all times. and what is the highest egts the trucks can handle and how long can i hold it on the floor before they get two high i am planning on running the 210 in both with the dpf/cat delete.
Any advice will be apriciated. |
You will be fine with the 210 tune. It takes a long time for the EGT's to hit 1600-1700 with the 210. Once you get to that point you dont want to hold it there, but its ok for a few seconds.
The 210 and under tunes have safety parameters built into them and defuel if stuff starts heating up, defuels at 1400 or so I think for EGT's, not sure on the rest. And no you don't really need to monitor it with the dashdaq unless your towing, then it would be a good idea.
thanks that awnsered most of my questions. and thats good that they have safety parameters built in. one is my daily driver KR f250 and the other is a wrecker F450 4x4 and i drive the piss out of it.
Oh and the F250 is a job 1 truck should i expect any problems from it with the 210. not worried about the F450 its a job 3. any input will be apricaited
The 210 tune will do just fine man
Thanks. i was just curious because i have heard that job 1 trucks have had tranny problems with the spartan. its ben to ford twice one time for the cooling system failure and the front main seal
Ok thanks. just out of curiosity did youre truck have any problems like mine
No, but I have a nice long list of problems from before I did the Spartan tuner and DPF delete
