how much boost with spartan 275
im running the dpf/cat delete with striaght exhaust...and a s&b cold air intake...spartan 275v4...just curious as to the boost u r seeing.....i see round 38....i could of swore i use to hit higher...but prolly mistaken
same set up as you, and im seeing the same numbers.
Pretty sure mine was higher before also. Believe the new tune does have a little less boost but im sure it is done for a reason.
ya well i had a pretty serious turbo hecup last nite at the pulls....when i let out...and it scared me but im thinkin i just for some reason had higher numbers in my head...
mine does that too once ya get to the end. Where did you pull?
poplar bluff,mo
i know this is probcrazy question but where the hell is this boost on the DD
Manifold gauge Pressure
Same set up basically...the highest I noticed before the spartan was 37. Now I'm getting 38. No big deal but mines the same as yours
