Testing Spartan TCM new product
Well I got a test version of the new TCM today and installed it in our F450. This is a job1 truck with 4.88 gears and 35" tall 19.5's. The truck has been running the a few different versions of the 310 tune with great success. The transmission has Suncoast parts inside including the direct solenoid, and I'm also running the Suncoast converter 65-3D. The product is designed to work with the stock transmission/converter, it just some happens my truck has had this Suncoast stuff in it for a long time. Shifting with the 275 and the 310 has always been good and firm just the way I like it, but until now I didn't think the harness that came along with that could be changed. I swapped the TCM's(was already programmed to work in this truck), fired the truck up and went for a ride. At first I thought "it doesn't feel much different", came to the first stop sign and whipped it coming out. Shifts changed this time, but it's kinda hard to put words to it. At the next stop sign I shut the truck off and restarted it, things improved again on this run. Each time the truck shifted thru the gears it got cleaner and faster on the shifts. It has basically stayed the same on overall firmness, but the speed at which it shifts is reduced. In doing this, the "harshness" has been reduced(almost removed). It leaves the shifts just very frim,clean, and fast. I will keep posting info, as some programming changes are going to still be made after talking to Matt for a while tonight. This was just the first test, and I'm very impressed. Great job.
This is good news. I have the 310 in my job 1 and sometimes when it shifts, it shifts so hard that I get surge cause my foot cant maintain constant pressure on the pedal.
Dont mean to take away from the thread but you going to shcieds? Talked to Rudy and he wasnt sure. Like the downpipe by the way! And did you mean harshness in your post? Im assuming yes. |
I don't think were going to make the trip, got some other "projects" I need to spend time with. Thanks for the comments on the downpipe fit and quality was my main goal, I think we got it.. Yes harshness, spelling is bad cause I forget to proof read. Sorry.
No problem on the spelling. Haha. Im a nitpicker. So this is just an updated tune and the module on the frame rail?
Yep, module and program to go with it. What a difference, and we still got a few weeks to work on making it even better.
I cant wait for these to be realeased!
I may even make a drive to go and see Matt in person. |
does it help in the job1 TCM's shifing into OD under full throttle? Part throttle they shift at about 50mph but mine won't under ft. heard it was the early TCM's that have this problem. Is it worth updating to a newer one?
Full throttle shifts are timed perfect. Shifts repeat the same time and time again, where as before it kinda did what it wanted to. The 310 tune seemed to correct alot of the shift irregularities, but the TCM cleaned it up the rest of the way. Matt should be getting me an updated tune this weekend, I think were going to firm up the 1-2 and 5-6 shifts. They seem pretty good to me right now, but a little firmed can't hurt. Hopefully Matt send it this morning before the rain hits, can't really drive it in the rain because of traction issues.
