Question for those of you with nitrous....
I just purchased a ZEX nitrous kit for my 6.4...and im having trouble getting it setup because i have to tap into the TPS sensor to get it to operate and I have absolutely no idea which of the seven wires that run into the throttle pedal under the dash to tap into..does anybody have any suggestions.
also if I didnt want to tap into the tps is there anyway I can bypass that and set I up as a push system..thanks for the help. |
anybody??
come on guys...
Here is a bump bud!!!
Call John at Cobbs Diesel he should be able to help you
thanks guys yeah I think ill give him a call! anyone else?
I just did a kit on a 6.4 and used a WOT switch mounted to the pedal. You can pick up a switch anywhere they sell kits.
We carry ZEX and install them quite often, they are very easy to use and install, provide great directions and are very high quality! The ZEX systems include a TPMS switch and also can be setup on a push button which is included in the kits. PM me if you have anymore questions were here to help!
Use the push button I have mine wire into the Horn just flip a uplifter switch to activate the remote bottle opener and horn to activate the nitrous.
