Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
  #31 (permalink)
Old 11-02-2009, 07:19 PM
08stroker250 08stroker250 is offline
Cobb's Diesel Performance
Originally Posted by Danbonzo View Post
Thanks Jeff. Always wondered about that. If they can make the 310 so it doesn't throw a code @ all, couldn't the other made egr plate tunes include the same as not to throw a code? The intent is to totally disable egr valve if the plates are installed right? Also is it true that the race tunes (less 310) cycle the valve once @ startup even they're disabled, would that explain the code if it's thrown, and why one can't run plates unless tune is specifically made. Sorry this is scattered all over the place, trying to watch yhe series as I type this
Ok, to my understanding some of the late 310 beta files were used to test somet hings needed to do a complete EGR delete, therefore the files had to be made where there would be no codes or drivability issues. Matt made the production file the same way I guess.
The 275v4 may be the same way....I am not sure though. The EGR valve is disbaled through tuning while driving. It will cycle at idle, not just at startup. When the plates are in there, the valve will still attempt to cycle, but the plate being there dirupts that....causing a code. The purpose of the plates is to block off the EGR coolers, not the valve, but there is a plate at the top of the uppipe where the valve is. Since the 175 and lower tunes dont have the EGR disabled, it is cyclying constantly. This causes drivability to be effected along with the code. I have tested this for John. My truck got to where it would not boost more than 25 psi on the 150 tune. I changed back to the 210 tune and it was fine....other than the codes. Spartan rewrites tunes for the EGR delete's though, so thats not big deal.
I hope that helps you out, that was also very scattered lol.
  #32 (permalink)
Old 11-02-2009, 07:33 PM
Danbonzo Danbonzo is offline
Gotcha, thanks
  #33 (permalink)
Old 11-03-2009, 03:37 AM
XPLOSIV XPLOSIV is offline
Does anyone know how much it costs for the EGR delete/block off re-write for the 210 and 250. Is that tune something you can have installed when first purchasing your dashdaq or do you have to get Spartan to make you a file to download(if you don't buy directly through Spartan) Those are the only two I plan on running when I get my Spartan. Soon, so soon!
