Trans Upgrade? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 08-07-2009, 11:04 PM Thread Starter
Trans Upgrade?
Is the Suncoast Direct Solenoid a worthy upgrade?
What is involved with install?
Is the MagHytec Trans pan a worthy addition also?
Thanks
Spatel23 is offline
post #2 of 20 Old 08-08-2009, 02:50 AM
powerstroker67's Avatar
I would say yes to both, if the tranny is in good shape put a converter in front of it all and now your really talking. The solenoid install is not much more involved than doing a regular tranny service/changing the internal filter, one clip and harness plug and the solenoid is out. Let me know if you need help, or have questions. We have all that stuff in stock. Sean
powerstroker67 is offline
post #3 of 20 Old 08-09-2009, 05:14 PM
sledfreak's Avatar
what's the selenoid do , is it good for a stock truck, how much are they?
08 6.4 250 cc sb lariat loaded white/tan 4x4
H&S Mini HD 300
MCC tunes
7 Kem tunes
Gearhead tunes
AFE S2 SI
Flow-Pro 4"SS
Turbo back
Areo-turbine xl
3"mbrp ci pipe
ccv mod
sledfreak is offline
post #4 of 20 Old 08-09-2009, 08:33 PM
I wanna go fast!
Flyin' Hawaiian's Avatar
It increases line pressure for the 3 to 4 shift to reduce wear on the direct clutches
2008 F-350 6.4L, KR 4X4, outfitted by South Texas Outfitters, its stock
+ Spartan and KEM
  • RIP: 95 F-350 Powerstroke, 4X4, 5 Spd, CC, LB, 4" on 35" BFG AT, DI 4 Bank, 4" pipe, DIY Tymar, Ranch Hands
  • SOLD: 2004.5 Cummins, 4X4, Billet DTT, FASS, TST, SMARTY, Flux, Helix, 2-CP3, 2 Turbos, 5" pipe. (893 on fuel )
  • 2007 Chevy 2500 Duramax, EFI by PBD, Suncoast.
PBD Diesel Performance
Flyin' Hawaiian is offline
post #5 of 20 Old 08-10-2009, 06:05 AM
08stroker250's Avatar
I noticed a change in shifts with mine. Firmer and more direct shifts is what I have noticed. I have a stock DPF delete file, and I'm not sure how much, if any, Matt messes with the tranny tuning, but I notice that te 3 and 4 shifts are firmer than my dads completely stock 6.4....
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #6 of 20 Old 08-10-2009, 06:48 AM
CobbsDieselPerformance's Avatar
The Suncoast Direct Solenoid increases line/holding pressure when shifting into 4th gear (i.e. - 3rd Shift.) It doesn't actually affect the harshness of the transmission shifting if the TCM is able to go through a relearn. The easiest way to explain it would be this, it increases the actual holding pressure of the direct clutches under WOT to prevent slippage and wear. Most 5r110 failures are related to direct clutch slippage and failure.
CobbsDieselPerformance.com :: 866-380-3076 :: Suncoast 5R110 Direct Solenoid
CobbsDieselPerformance is offline
post #7 of 20 Old 08-10-2009, 07:11 AM
sledfreak's Avatar
Thanks for the info guys
H&S Mini HD 300
MCC tunes
7 Kem tunes
Gearhead tunes
AFE S2 SI
Flow-Pro 4"SS
Turbo back
Areo-turbine xl
3"mbrp ci pipe
ccv mod
post #8 of 20 Old 08-10-2009, 09:54 AM
hunterc's Avatar
what would a direct solenoid cost?
Peter
08 Black FX4 F-250, CCSB, FloPro 4" straight, Banks dual exhaust, Spartan 310 & 275, Suncoast solenoid, EGR plates, S&B CAI, Readylift coil spacers in front/blocks in the back, MB Offroad wheels, 35x12.50R20 Toyo M/Ts, black billet grill, custom smoked mirror, tail, clearance lights and 3rd brake lenses, custom painted fender vents w/ chrome billet inserts
hunterc is offline
post #9 of 20 Old 08-10-2009, 09:56 AM
Look at the link Cobb's posted up. It's a direct link to the product on his website
Jeff Dodd
post #10 of 20 Old 08-10-2009, 09:57 AM
hunterc's Avatar
Haha my bad. Good point. Guess I should have read a little closer
Peter
hunterc is offline
