Question for Spartan - Ford Powerstroke Diesel Forum
Old 08-05-2009, 05:31 PM
Since I'm now running my truck "off road" with your 210 DPF delete tune can I now run low sulfur diesel fuel? I'm assuming the only reason I couldn't before was due to the DPF.
Thanks
Old 08-05-2009, 05:34 PM
With the 210 or above you should be fine. The only "threat" posed by LSD after DPF removal is sulfer/ash/soot buildup in the EGR system if it is being used. With the 210 and above the system is shut off and you should be fine.
Old 08-05-2009, 07:51 PM
Send a message via AIM to F250stroker08
Talk about customer service...dude had a question and it was answered 3 minutes later!!
Old 08-06-2009, 05:03 AM
Thanks Matt for the quick response as thats exactly what i needed to know. Every now and then i'm in a area where its harder to find the ULSD so in these cases i'll use the LSD instead while running the 210.
Thanks for developing the Spartan product.
