Spartan Fuel economy on long trip with light load - Ford Powerstroke Diesel Forum
post #1 of 24 Old 07-21-2009, 05:46 AM Thread Starter
My friend and I drove from Houston, TX to Salt Lake City, UT and back last week (4k miles) in my superduty with 1 sportbike in the bed, and 2 more on a 5x8 utility trailer. The 3 bikes + trailer + gear totalled ~2k lbs. Running the Spartan 275 v3 tune we averaged 16.5mpg running 74 mph down the freeway. Lie-o-meter read ~22 mpg the whole time. My truck is a 250 SRW CC 4x4 with 3.73 gears. I hope this helps give people a decent long-trip estimate on mileage.
As an aside, going up some mountain passes in western CO the EGTs climbed to about 1100° when we left the cruise on. Not to shabby in my book.
po-po 5.0 is offline
post #2 of 24 Old 07-21-2009, 05:54 AM
AED F250's Avatar
Good info! Are you running on stock size tires? If so, I wonder how a set of 37 inch tires with the 3.73 gearing would affect milage at cruising speed....hmmm
Also, if you are on stock tires how can the lie-o-meter so far off?!
2008 FX4
Fabtech 8 w/37's
Intake, delete pipe/exhaust, Spartan/KEM tuning
567 RWHP/1128 RWTQ
13.3 @ 103.9 MPH
AED F250 is offline
post #3 of 24 Old 07-21-2009, 06:01 AM
08stroker250's Avatar
Good stuff right there
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #4 of 24 Old 07-21-2009, 07:17 AM
Its not a lie-o-meter, its a fool (fuel) computer, coupled with a fool gauge.
2008 F250 Lariat CC 4x4 white/gold
n4hhe is offline
post #5 of 24 Old 07-21-2009, 07:18 AM Thread Starter
Stock tires. Only mods to the truck are a Spartan 275 v3, S&B intake, and powerstroker67 delete pipe.
My friend and I wondered how the lie-o-meter could be so far off. The only thing we can figure is that the ECU passes injector pulse width info to the trip computer, and the trip computer uses stock fuel info in order to calculate economy. However, because the rail pressures are increased, you're actually getting more fuel for a particular injection event than the trip computer knows about.
post #6 of 24 Old 07-21-2009, 07:23 AM
I'm in the Houston area as well. Where did you purchase your Spartan and other parts. Also, did you install yourself or have it done. Thanks
sinisdog is offline
post #7 of 24 Old 07-21-2009, 08:30 AM
correct me if i'm cause i don't know everything about thee trucks..but you're saying that because the fuel pressure is raised that there is actually more fuel injected.. the programmer should be telling the computer to inject less fuel at a higher pressure to achieve the same atomization
09 white fx4, icon leveled..37x12.50 toyo mt,20in rockstars,spartan 275,4in tbe,s@b intake
hammett88 is offline
post #8 of 24 Old 07-21-2009, 09:01 AM
BigKid's Avatar
There are a couple threads on here about the lie-o-meters and being off and what not. I think it is pretty common. Mine is off, it was off before tuning, and is still off with tuning.
2013 Platinum
2013 Explorer sport
2011 CTS V
BigKid is offline
post #9 of 24 Old 07-21-2009, 09:03 AM
DavidPhillips's Avatar
I believe the mpg calculation is based on calibration that is programmed in. It has no idea that there is more fuel injected it just knows your going faster for the calibrated amount of fuel / air ratio based on air flow so it shows your mpg is higher than it actually is when you install programming to increase fuel.
Going with larger tires will change the speed calibration to show less mpg. If you increase fuel and tire size and do not calibrate for the bigger tires the two would somewhat offset each other.
All my touring photos. (except the two massive trips in 2011-soon to be posted eventually)
-david
/ 2011 F250 4x2 Crew Cab /
Replaced "The Beast" 6.4L with 75,000 miles. Hated to see it go.
DavidPhillips is offline
post #10 of 24 Old 07-21-2009, 09:08 AM Thread Starter
Purchased a package from Rudy's Performance. Did the install myself in my driveway. Took about an hour.
Atomization isn't what makes power. More fuel is what makes power.
