Will they void the warrenty
So back with a Ford (the last Ford 2000 F350 went through 5 Auto Trannys) after 3 years with a Durmax that drank a quart of oil every 100 miles.
So the new ride is a 08 6 speed manual F350 SWD Crew 4x4 Lariat package. The exhaust cleaning program has to go. Is there something out there that will not leave a foot print? What about a exhaust brake to slow this thing down? What else is there that will help it out. I haul a 3400lb slide in camper with a 18 foot car trailer loaded with toys, I did buy the extended warrenty 4 years/48,000mi. I don't want to give them any reason to void it. |
If they catch you with a tuner installed, they can void your warranty. It's up to them. Key word though is "catch".
What ever you do, revert it back to stock prior to having any warranty work done. |
Yea, Spartan should not leave a traceable foot print as long as they just do a normal dealer scan. If they really went in debth they could probably find it.
The list: 1. 5" downpipe back exhaust 2. AFE Stage II or S&B cold air intake 3. Spartan Diesel Tech tuner (you choose the tunes you get) 4. Maybe a clutch depending on the power you go with 5. BD Power MIGHT be coming out with an exhaust break, no recent word on it though ***Most important thing is to put the truck back to stock (exhaust, cold air intake, tuner, everything) before you take it to the dealer for any kind of warranty work. Ford is probably going to be trying harder than ever to void warranty work. So the truck would probably need to look as it did the day you drove it off the lot. |
GO WITH SPARTAN i just put mine in tonight it took 2hrs with the install of the programs and the delete pipe and i did it at work on the gravel parking lot with a set of rachets. the power is amazing!
I found an oil leak on my truck last night. Only has 35900 miles on it. So I just put it back to stock and should be good for the warranty?
Should be.
