New 09 F250 6.4 Mods
Thought I had saved a post regarding what modifications work best for the 09 6.4L F-250, but I can't find it. What modifications have worked best on the 09, as far as exhaust, in take, chip? Thanks.
exhaust: visual appeal only
intake: most throw check engine lights without a tuner, and add almost no power. Basically, tuned trucks run them to avoid sucking in the filter minder. Tuner: Spartan is the favorite, followed by an SCT livewire with tunis from innovative. |
^^^^^^ what popo said.
Other than, my truck didn't throw any codes with my intake. Then a couple weeks later got my Spartan ![]() , then the exhaust. Exhaust just made it sound cool at WOT. But I would advise Spartan, the Dash Daq is awesome when it comes to monitoring and keeping an eye on things. |
So I go w/Spartan tuner, no different intake. Not putting on a different exhaust for better performance/sound is a bummer. Had Magnaflow/Aeroturbine on last and worked great.
I would go ahead and get the intake. It is recommended. They sell package deals if you go their site.
Which exhaust did you put on?
My bad. trying to get hang of forum posting. Which exhaust and intake did you go with?
I personally went with the AFE, and I had MBRP on my other trucks, so that was my choice for exhaust with this new one. But there are a lot of options out there, and some great deals.
The stock exhaust on these trucks is 3.5" (larger in some places) so it doesn't benefit nearly as much as earlier trucks. |
Go with a S&B intake, the afe I had kept throwing a code so after switching to the S&B no codes, and yes if your going to run a race tune 250/275 go with the intake, for the exhaust I just removed the DPF/Cat and left the remainder of the exhaust there, so with Spartan and a S&B your set to go, PM Aaron @ Rudy's Diesel performance and he will set you up with everything you need, then all you need to do is save some spare coin for new back tires!!
