Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Tranny Problems
  #31 (permalink)
Old 10-03-2009, 03:25 PM
HoosierHick HoosierHick is offline
Actually mine did the same thing today for the first time at 36,500 (bought it at 30,000), I was getting on here to ask you guys about it! Just like you said it was about 30 mph around a turn and then wham it slammed into gear, like a necksnapping slam, did it twice today. After the second time, it got stuck in 3rd gear while accelerating and hit like 3000 rpms to get to 55 when it normally takes about 2000?
  #32 (permalink)
Old 10-04-2009, 07:14 PM
DavidPhillips DavidPhillips is offline
I still have not noticed this on my truck. However I did notice the back wheels spinning tonight around 70 mph. The road was wet.
  #33 (permalink)
Old 10-05-2009, 01:26 PM
If this had happened on your truck you would definitely notice, it is like a headsnapping slam.
  #34 (permalink)
Old 10-05-2009, 02:29 PM
wontonrunner wontonrunner is offline
So, after my tranny flush they took it for a drive arround the parking lot and monitored the pressures. Everything is in spec and nothing out of the ordinary. Tranny shifts in stock form are not noticeably different with 100,000km's on oil vs the brand spanking new oil.
Now that I have new oil I will keep track of mileage and frequency that this occurs in my truck. Perhaps it is related to the oil? ie. as you put more miles on the oil it happens more frequently...likely not, but who knows.
All I know is that the complaint is in, my truck has fresh oil and its still under warranty and I will continue to make the complaint when it happens so that if the tranny drops out after my warranty period i can say to the dealership that they new it was just a matter of time.
  #35 (permalink)
Old 10-25-2009, 09:08 PM
idkillinit idkillinit is offline
Yea my truck used to just do it occasionally on the NEW trans.. Only 7k on it.. I never stopped beating the piss out of it or detuned it tho.. So just friday i noticed the convertor taking longer to lock up under wot and then slipping more sometimes so i started taking it easier but then....... My gf's little brother and his buddies were runnin off at the mouths last night about there friends dodge that was so bad ***.... Long story short i drug that **** backwards about 100ft... then i decided to do it in 4 high and after i drug it again the shifter was sort of stuck and the convertor wouldnt engage..lol its almost like it has a really big stall but slams everytime it takes off and i have to stay on the throtle a little while i stop to get it to down shift.. Oh well i was looking for an excuse to build a real trans anyway. Ford would prolly replace it again but the obviously cant build one that can take abuse..
  #36 (permalink)
Old 11-17-2009, 10:25 PM
briscoe briscoe is offline
My truck did this the other day as well, on the 210 tune. It did it twice in a row, put in a quarter quart of tranny fluid and it has not happened again for two weeks. Thinking to just run stock, don't need no extra headaches. This never happened on my 6.0.
  #37 (permalink)
Old 11-18-2009, 08:16 AM
It happens when stock as well...so why not at least enjoy driving it...
  #38 (permalink)
Old 11-19-2009, 06:48 PM
Big Angry Hillbilly Big Angry Hillbilly is offline
Torqshift will see a failure of a clutch element and stop using that element.
By clearing the code, you allow the trans to re-engage that element, and cause further damage.
Also, by clearing the code, you've made it a pain in the nuts to diagnose. It can take up to SEVEN full drive cycles to set codes in a Torqshift.
Changing the filters/fluid won't do anything for this concern, I'm betting.
Check with your dealer, your truck may have powertrain warranty.
