Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Tranny Problems
  #31 (permalink)
Old 05-15-2009, 09:00 AM
BIGWHEEL450 BIGWHEEL450 is offline
Truck is back and seems to be shifting well He showed me the discs and the where all burnt bad he said he was not sure what caused it to get that hot and I had never seen the temp gauge get over straight up Anyone have an idea or similar experience
  #32 (permalink)
Old 05-15-2009, 10:07 AM
alwil alwil is offline
What is a built 5R110 for a 6.4 worth?
  #33 (permalink)
Old 05-15-2009, 11:45 AM
$3500-$4000 when I last checked
  #34 (permalink)
Old 05-15-2009, 01:15 PM
dzchey21 dzchey21 is online now
it only takes one or two decent slips to make a clutch pack burn up and more than likely you would have never seen it on your guage because the gauge reads converter outlet temp, so the hot oil would have gone right into the pan and been picked up by the pump and then into the coverter, mixed with the other oil by now so i doubt it would have showed much.
Alot of things can cause that, slow moving spool, or solenoid, you may have never even felt it, it could have happend in a gear change and it was dragging that clutch pack while the other was engauged at the same time, hard to say but im glad you got your truck back
  #35 (permalink)
Old 05-15-2009, 03:10 PM
Does that include TC,aftermarket VB and transgo?
  #36 (permalink)
Old 08-11-2009, 06:18 PM
hunterc hunterc is offline
So a suncoast direct solenoid (which inproves 3rd to 4th shifts) is a worthy investment then since that's the weakspot
