Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Tranny Problems
Old 04-09-2009, 04:26 PM
beaky73 beaky73 is offline
911 tranny help
hello to all. today i changed my tranny oil via the drain plug and now whenever i go somewhere there is puddle of tranny oil. cant tell where its coming from, look like were the pan meets the trans. any ideas? there is 17000 miles on the truck.
Old 04-09-2009, 05:26 PM
i think it is coming from the pan. i went to tighten the bolts and some of them just spin. hs any one hand this problem. what would cause this?
Old 04-20-2009, 06:42 PM
Hollywood2005 Hollywood2005 is offline
Sounds like they are stripped.... not a good thing if that is what it is!!
Old 04-20-2009, 06:54 PM
forcefed6.4ford forcefed6.4ford is offline
Tap out the holes and up size the bolts. Next time dont tighten them up so much.
Old 04-20-2009, 07:10 PM
powerstroker67 powerstroker67 is offline
Sometimes you can clean up the holes and run a 8x1.25mm tap thru them and run a longer bolt. The factory bolt only goes part way thru the tranny case. Another note for those of you removing the pan for tranny/filter service or other stuff, clean off the rails of the case before removing the bolts to prevent the junk sitting on top of the bolts to get into the threads. Most times this dirt/stuff in the threads causes the bolts to strip going back in after the pan is down. I know that this doesn't seem to be thge case here, as he said he just drained the pan, but just some helpful info. I'd try the longer bolt and cleaned up hole first, that should work. Good luck.
Old 04-30-2009, 08:41 AM
djen223 djen223 is offline
did you just drain out of the plug or drop the pan, if the pans bolts are stripped and you didnt drop it id be talking to ford/?
