Odd thing happened with shifting - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 01-08-2014, 09:33 PM Thread Starter
smlarkin's Avatar
I have been looking through all the past posts but haven't found anything directly covering the symptoms I had so I wanted to see what you guys thought. A while ago I was slowing down to get on the freeway and while I was coasting into the right hand turn I gave it gas when my truck was straightening out and the tranny felt like it made a hard slam. I didn't think much of it at the time, thinking it was cold or some freak thing because I have never had any problems before but today it did the same thing and on the same turn. It has only done it these few times and only on a sweeping right hand turn while I'm coasting in then giving it gas. The only thing I have seen is something about a GoGo solenoid but I don't know if mine is having the same problems or if it will fix it.
Thanks for the help.
Shawn
2008 F250 Lariat Crew Cab, Pro Comp Lift, 35" Toyo's on 20" wheels, AMP Research, Air Bags
smlarkin is offline
post #2 of 14 Old 01-11-2014, 09:17 PM
srjd's Avatar
Quoted: 2 Post(s)
There's lots of guys with this problem. Mine only did it once then was stuck in 3rd. Same thing let off on a merge then floored it felt like I hit a curb. I'm pretty sure to go go will fix it
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 14 Old 01-12-2014, 06:08 AM
Lunchbox21984's Avatar
Mine has done this a few times as well. Where is the solenoid located?
2008 F250 6.4Ltr, 4X2, Crewcab w/ Shortbox
Lunchbox21984 is offline
post #4 of 14 Old 01-18-2014, 02:50 AM
srjd's Avatar
Quoted: 2 Post(s)
I ordered the solenoid from ptp.its suppose to shift a lot better and fix the issue. I'll post back when I get it installed
srjd is offline
post #5 of 14 Old 01-24-2014, 09:36 PM Thread Starter
smlarkin's Avatar
Thanks for the help I appreciate it. I will order one of those solenoids as well and let you know how it goes. I have been wanting to order a Mag Hytech deep pan for my tranny anyways so this will push me more to get it done.
Shawn
smlarkin is offline
post #6 of 14 Old 02-12-2014, 07:56 PM
silver93's Avatar
what is this solenoid actually called my trans shifts crazy at times
silver93 is offline
post #7 of 14 Old 02-13-2014, 05:13 AM
spock91's Avatar
Quoted: 6 Post(s)
spock91 is offline
post #8 of 14 Old 03-01-2014, 02:11 PM
blackcloud2k's Avatar
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
You can also add an additional 1/4-1/2 qt of tranny fluid and a lot of times it will go away. The solenoid is the 100% cure though. The mag hytec deep pan is also a nice upgrade but there is a stipulation. It will take longer for the fluid to get hot which is nice, but it will take longer for it to cool down as well.
2015 F350 Ruby Red Platinum, SRW CCLB, Color matched Ranchhands, rigids.
SOLD:
blackcloud2k is offline
post #9 of 14 Old 03-06-2014, 10:03 PM
deamsphelps's Avatar
Originally Posted by spock91 View Post
In the pictures of the install, it looks like the tranny is removed from the truck and the tc is removed. Can this part be replaced by dropping the pan? Only had my pan off once and that was just for fluid and filter.
deamsphelps is offline
post #10 of 14 Old 03-06-2014, 10:07 PM
silver93's Avatar
Come to find out the clutch and everything else was smoked in it. On a good note it was a factory reman and was still under warrenty. So ford is replacing it free of charge. Got lucky on that end of the deal I guess
silver93 is offline
