heres a stumper, Please help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-01-2013, 12:50 PM Thread Starter
fiderius22's Avatar
ok fellas, ive done all i can do and i am still stumped. attached is the link to a short video. The backstory is so:
PATC torque converter failed, got 2 codes P0741 and P1744. In lieu of the amount of work i have going and can't afford to have the truck down, we dropped the trans and threw the stock converter in until PATC sends a new one. Well once the truck was back together, it made this noise immediately. We thought the starter may have gotten damaged (it got arced pretty bad) so i threw a new one in and it didn't change a thing. The noise is intermittent, comes and goes. Trans temp is normal, maybe a little low. only saw 150 degrees after a 15 minute highway cruise. All tc bolts are tight. Please see video at 6.4 bell housing noise - YouTube . Any help is greatly appreciated.
08 6.4 F-250
ARP studs
Rudy's coated/machined pistons
CX Aluminum intercooler
No Limit ic pipes
ccv Reroute
AFE MF intake
PTP EGR delete w/ elbow
Diamond Eye 5" dp back with MBRP 7" tip
H&S Mini HD300
PATC triple disc billet tc
PATC stage 3 built trans
6" 4-link rough country lift
PMF stage 2 trac bars with gussets and block mount
20x10 XD Revolvers with Federal 35 MTs
Advantage Max-4 wrapped bumpers/grille
Reflexxions steel cowled hood
5% tint
Kenwood nav/dvd
fiderius22 is offline
post #2 of 4 Old 12-01-2013, 12:51 PM Thread Starter
fiderius22's Avatar
noise is seemingly directly out of the bell housing.
08 6.4 F-250
ARP studs
No Limit ic pipes
ccv Reroute
AFE MF intake
H&S Mini HD300
5% tint
Kenwood nav/dvd
post #3 of 4 Old 12-14-2013, 07:17 AM
Powerstroke Techie
Flexplate busted? Converter nuts loose?
I had a 6.0 this week that I swapped engines in that had a pile of starter shims in it, because the starter was hitting the flywheel once the starter was disengaged after crank, but it was a LOT louder than that and constant, so I think you could probably rule that out.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #4 of 4 Old 06-19-2014, 01:30 PM
groove's Avatar
I know this is an old thread, but I am having a similar sound. Replaced TC and still there.. Pulled flex plate and not cracked. I have a new one to go in but wondering if I am just tossing cash at it. Pulled started and gear retracts all the way.
Any ideas??
08 F350 CCSB 4x4 01/07 Job 1
0.030" de-lipped slugs, 70+ atmosphere turbo, ARP studs, Mild Ported Heads (w/bronze guides), Flo-Pro EGR Delete
Mini Maxx Race tuner, AFE exhaust turbo back, S&B Intake, Sinister coolant filter
Lifted nicely on 20" wheels
groove is offline
