HELP!!! Trans. Feed Line - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-17-2013, 07:13 AM Thread Starter
Trigger01's Avatar
Yesterday I went and picked up a big load of square hay bails; when I got back I noticed that I was leaking a little fluid under the truck. I moved the trailer into the barn and had a steady stream of trans. fluid from the truck. Thankfully it appeared to have all let go once I was back at the farm and not on the road.
We determined that it is the trans. feed line had a hole on it from rubbing the oil pan. Truck is almost empty of trans. fluid. I am going to call Ford tomorrow and get the line, but is there anything I should know about replacing the line, what to look out for etc? Do I need to bleed the line or just replace the line, refill the trans fluid and good to go?
Thanks for the help!!!
2008 F-350 Lariat 4X4 CCSB
Trigger01 is offline
post #2 of 3 Old 11-17-2013, 09:42 AM
Powerstroke Techie
Put line on, fill trans and hope for the best.
Any automatic trans doesn't like being run low on fluid.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 3 Old 11-17-2013, 09:59 AM Thread Starter
Trigger01's Avatar
I'm thanks. It was only moved about 100 feet backing up a trailer so hopefully it won't be too bad
