Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Tranny Problems
  #11 (permalink)
Old 09-19-2008, 09:20 AM
Dusten Dusten is offline
Send a message via MSN to Dusten
with yuor lift, i would start looking at the track bar, make sure the bolts are tight. next, the track bar drop bracket, loosen its bolts and retighten. if you have the pro comp stage 2, check the radius arm bolts too.
I fought this for a while with my old skyjacker lift. the drop bracket was constantly working loose.
