Front transfer case blown seal - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-25-2013, 07:25 PM Thread Starter
NDF250KingRanch's Avatar
Going cross-country and noticed tranny fluid all over ground. got tow to nearest Ford Dealer. The truck only has 30,000 miles. (damed in accident, no warrenty. is this common for the 08' F250 SD. hopefully we noticed in tim and didnt ruin the front end trasfer case. Any info would be appreciated. On the good side weve traveled 3,000 miles on the trip and have been getting 15mpg.
NDF250KingRanch is offline
post #2 of 2 Old 07-25-2013, 07:36 PM
xpbprox's Avatar
Are you taking about the front axle differential?
There's only one transfer case and that's right behind the tranny.
If its the front axle then it will be a thicker oil and you're probably fine. Just need some fluid and reseal the front cover
04 F-350 XLT FX4 CC LB SRW leveled, SCT w/ innovative tunes, Edge Insight gauges, Str8 pipe, Studs, Bulletproof EGR, valve seats, 6.4 banjo bolts, updated fuel pressure spring
89 F-350 Centurion Lariat 4X4 CC BB STW lifted on 35"s
460 E4OD
6.0 BIBLE
xpbprox is offline
