Tranny or motor? Gogo solenoid? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-31-2013, 03:28 AM Thread Starter
fiderius22's Avatar
Hello all I've read what I can and I think I'm stumped. my truck falls hard on her face when I really get in it. Almost like a total loss of power for a long second then its back. Trans fluid doesn't seem burnt but the h&s defuels for trans temp whenever I'm towing in city conditions, reaches about 180 pretty quick. I tow about 6k in the tow setting with tow/haul. Also reaches 180 after about 2 hard passes through the gears in performance (hd300). Had trans rebuilt with billet trip disk converter, all new stock solenoids, shift kit, and all red eagle clutches in December. The only slipping I notice seems to be in the 2-3 shift but when it falls on its face I can't really keep up with where the trans is at. Will the gogo solenoid help? Are these temps normal? Any help is greatly appreciated, can't afford another trans failure.
Sent from AutoGuide.com App
08 6.4 F-250
ARP studs
Rudy's coated/machined pistons
CX Aluminum intercooler
No Limit ic pipes
ccv Reroute
AFE MF intake
PTP EGR delete w/ elbow
Diamond Eye 5" dp back with MBRP 7" tip
H&S Mini HD300
PATC triple disc billet tc
PATC stage 3 built trans
6" 4-link rough country lift
PMF stage 2 trac bars with gussets and block mount
20x10 XD Revolvers with Federal 35 MTs
Advantage Max-4 wrapped bumpers/grille
Reflexxions steel cowled hood
5% tint
Kenwood nav/dvd
fiderius22 is offline
post #2 of 3 Old 05-31-2013, 03:29 AM Thread Starter
fiderius22's Avatar
No codes either btw
08 6.4 F-250
ARP studs
No Limit ic pipes
ccv Reroute
AFE MF intake
H&S Mini HD300
5% tint
Kenwood nav/dvd
post #3 of 3 Old 05-31-2013, 05:56 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
the 180 thing is a good thing... there is a thermostatically controlled valve in the trans that collapses flow to 10% when temp is under 180, it opens above 180 partially to flow more fluid, and is wide slam open above 200.. the optimum temperature of the trans and fluid is 180*.... what is your defuel set at?
I'd lean more on the motor... Have you checked your boots? how is your filter? what kind of fuel pressure are you seeing? it could simply be a lazy pump that doesn't react as quick as it needs to.
drewactual is offline
