Why does my truck fall flat on its face shifting into 5th at WOT (Tuned/ DPF Delete)? - Ford Powerstroke Diesel Forum
post #1 of 29 Old 03-31-2013, 03:09 PM Thread Starter
I am running IDP's Xtreme Street Tune (approximately +300rwhp) and I've been enjoying the hell out of it for about 5,000 miles. But lately, with the foot to the floor, the 3-5 shift goes completely flat. Feels like someone cut the power completely, then it sort of sorts itself out and keeps going. But when that happens, a lot of the time, when I come to a stop, the trans is stuck in 5th. I have to put it in park for it to go back into 1st. Then after that it might shift funky (shifts directly from 1 to 3, then gets stuck in 5th again), then it goes back to normal and the issue doesn't reappear unless I go foot to the floor 3 to 5 shift. FWIW, I do have the Gogo solenoid installed, fresh Motorcraft fluid, and a fresh Motorcraft filter. Truck has 69k on it, bone stock until 64k.
lxcoupe is offline
post #2 of 29 Old 04-10-2013, 06:42 PM
drhoades3862's Avatar
You need to upgrade the direct clutch solenoid.
drhoades3862 is offline
post #3 of 29 Old 04-10-2013, 06:43 PM
The 5R110 TorqShift transmission is one of the most robust transmissions ever offered in a medium duty pickup. It does however have a weakness. The 5R110 transmission is controlled through the use of solenoids to turn on and off gears. A gear is commanded by the computer and a solenoid applies fluid directly to that clutch. In stock power applications the stock solenoid is fine. Outside of that range, the factory piece cannot provide enough fluid to the clutch fast enough to get the clutches together in a short enough time. Long term slipping of the clutch leads to failure. Direct clutch is not only used for 5th gear in the transmission, but it is also used when in reverse as well.
post #4 of 29 Old 04-10-2013, 07:20 PM Thread Starter
I already have the GoGo solenoid installed, I'm installing a low mile 5R110 out of a wrecked truck next week...
'08 F250 Regular Cab 4x4 (sold)
MBRP dpf delete
MBRP intercooler pipe
S&B intake
IDP/ SCT tuned
Suncoast Trans (built by Quin Trans in Lompoc, CA)
Cal-Tracs
Eaton Tru-Trac
12.76 @ 105.50, 1.80 60ft (before trans or intercooler pipe)
lxcoupe is offline
post #5 of 29 Old 05-31-2013, 02:17 AM
fiderius22's Avatar
Question, my truck falls hard on her face very similar. Trans fluid doesn't seem burnt but the h&s defuels for trans temp whenever I'm towing in city conditions, reaches about 180. I tow about 6k in the tow setting with tow/haul. Also reaches 180 after about 2 hard passes through the gears in performance. Had trans rebuilt with billet trip disk converter, all new stock solenoids, shift kit, and all red eagle clutches in December. The only slipping I notice seems to be in the 2-3 shift. Will the gogo solenoid help? Are these temps normal? Any help is greatly appreciated, can't afford another trans failure.
Sent from AutoGuide.com App
08 6.4 F-250
ARP studs
Rudy's coated/machined pistons
CX Aluminum intercooler
No Limit ic pipes
ccv Reroute
AFE MF intake
PTP EGR delete w/ elbow
Diamond Eye 5" dp back with MBRP 7" tip
H&S Mini HD300
PATC triple disc billet tc
PATC stage 3 built trans
6" 4-link rough country lift
PMF stage 2 trac bars with gussets and block mount
20x10 XD Revolvers with Federal 35 MTs
Advantage Max-4 wrapped bumpers/grille
Reflexxions steel cowled hood
5% tint
Kenwood nav/dvd
fiderius22 is offline
post #6 of 29 Old 09-11-2013, 09:53 AM
Probably burned your motor up running IDP's Xtreme Street Tune (approximately +300rwhp).
I guess we will see in a few months...
GSchretter is offline
post #7 of 29 Old 02-23-2014, 05:54 PM
Lipka101's Avatar
Quoted: 87 Post(s)
Did the new trams fix your problem?
Lipka101 is offline
post #8 of 29 Old 02-23-2014, 07:03 PM Thread Starter
I never ended up installing the new trans, I still have it sitting in my shop. The shifting never got worse, I just learned how to drive it. If you have your foot to the floor the trans shifts great, but for some reason on the 3-5 shift if you're at like 1/2 throttle or more, it does something very strange, kinda like missing a gear or something. But at WOT it hits the gear perfect. My buddy who also has the IDP Xtreme X tune has the exact same issue with his trans. So at this point I'm not sure if it's a trans issue or tuning issue.
MBRP dpf delete
S&B intake
IDP/ SCT tuned
Cal-Tracs
Eaton Tru-Trac
lxcoupe is offline
post #9 of 29 Old 02-23-2014, 07:08 PM
Lipka101's Avatar
Quoted: 87 Post(s)
Yeah mine does it at wot. Used to do it worse. Like cut out for a few seconds but now it's like a slight hesitation. Do you have their newest tunes? I'm thinking of updating to the 3.03 and see if there's a difference.
2008 f250 ccsb kingranch
Sct Livewire with Gearhead custom tunes. Edge insight cts.
Mbrp dpf/cat delete. PMF stage 2 traction bars.
Drp egr delete w/wastegate. LP batmowheel, 22x9.5 fuel hostage with nitto terra grappler. 12.9 sec. 1/4 mile at 104.5 mph
Lipka101 is offline
post #10 of 29 Old 02-23-2014, 07:20 PM Thread Starter
I bought my tune from them in November of 2012 and I know I sent in my 9025OR to them so they could do the software update, but I'm not 100% sure if it's 3.03?
Cutting out--that's a 100% perfect description of what the truck does. If I'm between 1/2 and 3/4 throttle on the 3-5 shift, the truck will literally "cut out" and then it figures itself out and keeps going. If my foot is to the floor, the shifts are fine. I've just learned the perfect throttle position for the 3-5 shift (non WOT) where the truck will shift and not cut out. But it's extremely annoying. I figured I was looking at getting a built trans, but because my only issue is the part throttle 3-5 shift, I can't justify a built trans... and to be honest I'm not 100% sure it's actually the trans. My truck was bone stock 60,000 miles when I put the dpf delete/ S&B/ IDP tune and the "cutting out" weirdness was happening since the first day I loaded the tune. My buddy was so impressed with how hard my truck ran that he had me order him all the same stuff. We loaded all of it on his truck (76,000 miles) and it cuts out the exact same way. Sometimes when it cuts out and you come to a stop, the trans is actually stuck in 5th. I'd love to figure this problem out............ Eric@ IDP any ideas??
My fluid looks great, not burned, no clutch material in the pan or on the magnet... and yes I have the Go-Go solenoid installed. The Go-Go solenoid didn't make any difference in the "cutting out" one way or another...
MBRP dpf delete
S&B intake
IDP/ SCT tuned
Cal-Tracs
Eaton Tru-Trac
lxcoupe is offline
