TRANNY PROBLEM!!
ok i have a 2008 f350 6.4 with turbo back exhaust into two 6in stacks with an h and s programmer i unfortunately cant afford to build a mud truck so i bring this truck to every mudfest i went through a mud hole and got stuck the truck stalled then acted like it had a dead battery i checked conn.one terminal was loose i tightened it and the truck started but now will not shift into gear i can put it in all gears but i have no click no clank no grinding it just doesnt make any noise or movement at all like your not even moving the shifter if anyone knows what this may be i would appreciate your help...
jobystevens, |
you might of busted the linkage , being in the mud could of done it. might want to check that out.
check all of the cables, linkage and the the side of the trans. might be a neutral or park safety switch issue
I broke my input shaft today. Now the truck just sits there and revs like yours, nothing else. How hard were you gettin on it when you went through the mud? Mud is pretty hard on drivetrain components.
TRANNY PROBLEM!!
I've checked linkage it seems ok and I get on it real hard in the mud I act like I'm on a buggy
