Stuff in transmission fluid
My brother has a 08 6.4l with 30000miles with h&s programmer. He checked his fluid and it has what I think is fibers in it. Fluid is clean bit has these specs in it. Wondering if he could smoke a transmission with just that tuner? What is his transmission rated for HP wise?
Sent from my PC36100 using AutoGuide App |
After 300k ,even without a tuner you could smoke a transmission. The 6.4L trans has a really good reputation for holding a lot of power and taking abuse, but after 300k ,(probably with a lot of towing I would guess) even these transmissions can let go (especially if maintenance was late/missed).
He said 30k, not 300k.
Are they small gritty particles? This is usually due to rust in the dip stick tube it seems on these trucks. |
They look like fiber. Like flakes
Your right , looks like my old eyes added another 0 .
He finally had the fluid flushed and checked out by a Ford dealer. They said it was from the dip stick tube. Nothing to be worried about
Sent from my SPH-D600 using AutoGuide.com App |
I had the same thing happen, pull the dipstick and there were flakes/filings on it, I was quite scared, phoned ford they said it was normal, I booked it in for a tranny flush any ways and told the service manager to make sure the tube got cleaned out and it's been good ever since.
