tow/haul switch not working - Ford Powerstroke Diesel Forum
Old 12-26-2010, 07:48 AM
i recently bought a 2008 6.4L. i noticed that the tow/haul light does not come on when i hit the button. i have read that the shift lever is probably the culprit, but i dont want to break anything trying to replace it. could someone tell me if this is the problem or any other ideas of how to fix it. and if it is the problem how to remove and replace.
Old 12-26-2010, 08:51 AM
OK i did a little more investigation, it seems to be a chaffed wire because i can get it into tow/haul if i pull the shift lever back. how do i take the steering column apart to trace the wires. i took the three bolts out of the bottom of the column, but was not sure if it just pulls apart (top/bottom) or is there another bolt or something.
Old 12-26-2010, 09:13 AM
Just give it a yank top or bottom and they will come apart in the middle in 2.
Old 02-24-2013, 08:51 AM
having problems with my tow haul also---was it hard to fix the wire thanks gary944
Old 02-27-2013, 03:03 PM
Mine quit a while ago. Was wondering the same thing. Or where can I find a schematic to find a wire to put a regular switch on?
