Starting off in 2nd Gear - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-28-2010, 06:23 PM Thread Starter
Unhappy Starting off in 2nd Gear
in my 2010 F250 SD 6.4l, after really getting on it for a short period of time where the tranny seems to hiccup and goes into third and then right back into 2nd and then normal progression my next start-off from stop the truck starts off in second. It only does this for about 50 feet or so before dropping to first and then all is fine. Anyone got any suggestions on what it could be. I have the edge programmer on it but the edge evolution does not alter any shift points in the TCM.
crosstalk is offline
post #2 of 7 Old 09-29-2010, 09:07 AM
WoodBoy's Avatar
Did it do it right after you programmed it? I think you need to reprogram it, and drive normal for 70-100 miles for the tranny to learn
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 7 Old 09-29-2010, 09:39 AM Thread Starter
Nope. Its had the programmer on it since July and it has only done it twice, yesterday and one day last week. Still confused on why, no matter what it thinks its learned about me, it would try and start off in second gear.
post #4 of 7 Old 02-22-2012, 03:49 PM
Derek@VisionDiesel's Avatar
Send a message via AIM to Derek@VisionDiesel Send a message via Yahoo to Derek@VisionDiesel
My truck has been tuned for approximately 30 in town miles, and it did this today.
It hates shifting under heavy throttle and it started off in 2nd once today.
1996 f350- 615hp/1258tq uncorrected
2008 KR f350- leveled and tuned 569hp/1158tq
Cascade Coal Rollers!
Derek@VisionDiesel is offline
post #5 of 7 Old 05-30-2012, 06:22 PM
rocknmj's Avatar
Mine did sort of the same thing the other day. I slowed down for a corner to about 20mph and the gently got back on the throttle...tranny sounded like I had hit neutral then caught 3rd gear and stayed there till I stopped at stop sign. Weird thing is it didn't shift back to 1st when I stopped but stayed in 3rd (according to my MiniMaxx). It then seemed to take off in 3rd and only went to 4th before I hit the next stop. Did this all the way home (about 1 mile) and still did it after stopping, going to park, reverse, etc. So I shut it off for about 30 minutes and came out to try again and everything worked fine.
Any ideas? Was fine the next day when it went to town too. No codes or lights. Seems similar to original question.
2008 Lariat 4x4 CCLB DRW
H&S Mini, S&B Intake
AirDog 2, Beans Diesel Sump
DieselSite Coolant Filter, CAC Boots, Tranny Filter
rocknmj is offline
post #6 of 7 Old 06-05-2012, 06:56 PM
Mine does the same thing it hiccups
08 powerstroke f250 white lariat
H&S hot damn 300
Egr delete/ high flow intake elbow
3" cold side intercooler pipe
Arp studs/ oem gaskets
5" flo pro straight pipe from downpipe
Afe stage II CAI
Leveled/ 35" m16s on factory lariat 20s
Powerstrokin250 is offline
post #7 of 7 Old 06-20-2012, 12:42 PM
I have had that problem many times since I put the tune in 100k miles ago. the fix for me was having my traction bars tight. It sounds like you guys don't have any traction (ladder) bars, you NEED them, especially if the truck is lifted, mine has a 4". what's happening is the driveshaft is being pulled away from the torqe converter, caused by axle wrap. H & S has a youtube video here
hope this helps
HawaiiFordguy is offline
