310 tune funky OD lockup shifting - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-10-2010, 01:17 AM Thread Starter
Erikclaw's Avatar
When I get on it at about 3/4 or more it shifts fine, doesn't lock up at 45 like it should but when it shifts into overdrive it then immediately shifts out of the first OD. There are two od's correct. Each one is about 250 rpm difference. Say it shifts to 1750rpm immediately shifts out to around 2000rpm then a couple of seconds later it shifts back into od lockup. Under less throttle is locks up at 45mph. Full throttle forget it rev to 3000 for a while and od maybe at 75 mph. It is a Job2 I believe. Build date 09/07. I was thinking maybe the Spartan TCM would help.
2008 King Ranch 6.4L CC Elite LP & HP fuel systems, II pump, tow compounds, stage 2 ported heads, stage one cam, tow compounds, ported intake and manifolds, egr delete/wastegate, 60hp injectors, full Elite trans
Erikclaw is offline
post #2 of 5 Old 01-10-2010, 06:41 AM
You need to do a transmission re-learn. That is all messed up. It shouldn't be doing that.
And, no, this truck doesn't have 2 overdrives.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #3 of 5 Old 01-10-2010, 07:09 AM Thread Starter
Erikclaw's Avatar
well I know a chevy i had did have like a two stage overdrive. I did a relearn twice. Are you meaning when you reinstall, and go through a series of half throttle and higher accelerations? Did that twice and the same each time.
Erikclaw is offline
post #4 of 5 Old 01-10-2010, 07:23 AM
There is a prescribed method that Spartan tells people to do. It is something like:
25% throttle 0-65mph - done twice
50% throttle 0-65mph - done twice
75% throttle 0-65mph - done twice
35mph to 80mph roll with foot on the floor.
100% throttle 0-70mph - done 2-3 times.
You have to reset your PCM and TCM first though. The way you do that is by re-flashing to the 310 tune. Then immediately go and do the re-learn.
If you've done all of that, then I don't know what to suggest. You might have to email tech support if that doesn't fix it.
post #5 of 5 Old 01-10-2010, 09:33 AM Thread Starter
Erikclaw's Avatar
Yeah I did all that twice.
Erikclaw is offline
