AMP TUNing help
anyone have an experience with tuning an amp..
if so can you pm me.. I have a kicker l7 and a hifonix amp. was wondering how to tune an amp correctly i searched the net.. didnt find anything usefull. Thanks. |
hook it up to the speaker and turn the knobs all the way up!!!!
lol ya turn the knobs up. Go to rockford fosgates website they have a great tech section where you learn about ohms and the correct wiring, tuning ect. check them out and they sohuld answer anything you need to know.
i just set my bass and treble on the radio at high volume than tune the amp from there. i usually turn the gain all the way down. just trial and error. keep playing with the settings. you will get it right.
Bridge the speaker and i would set everything to half power and just adjust it from there
Bridging the speaker doesnt allways mean more bass. You need to know what the amps watt output is @ what ohm and also what the speaker is rated at in watts @ what ohm. If you get onto rockfords website they do a good job of explaining. On my rockford 1050s and 2 HX2's its actually better to wire the speakers one on each side to get the most power to the sub.
i have been reading and most of the setting are actually needed to be turned down.. its like a cut off level.. not the higher you go the louder it is..
i was just hoping someone had some true knowledge on here. ill try some other forums. thanks though |
your welcome
sorry guys.. just wanted some real help. not just crank it up.
i want quality sound not just loud distortion thanks for your input |
no hard feelings, i was directing you twords fosgate because they share information and explain why things need to be a certain way...
