Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
  #11 (permalink)
Old 03-10-2009, 07:01 PM
FX4STROKER FX4STROKER is offline
COTTONWOOD CREEK RANCH
every time you hit a bump does it fall down? I noticed that it does not close all the way. How do you like that mic? I need to get a new mic for my cobra
  #12 (permalink)
Old 03-10-2009, 07:05 PM
Goose350 Goose350 is offline
Obamacare..
That looks pretty darn good!
  #13 (permalink)
Old 03-10-2009, 08:38 PM
foursixtysix foursixtysix is offline
Send a message via AIM to foursixtysix
When driving it will stay up for a while then flop down, that's why I want to add some velcro or something, I wish that compartment had a nice latch to it or something instead of whatever return it has..I might try to find something a little neater than just velcro, but at least that would be easy to remove someday, I really wanted some solution that could be removed and not leave any holes or junk behind.
And the mic is fine, it's the one that came with the Cobra. I'm not a hardcore CB user so it does the job.
Thanks for the comments!
  #14 (permalink)
Old 03-13-2009, 11:36 AM
yukondiesel yukondiesel is offline
Hay Bud: That's the BEST idea I've seen so far! Nice Job! Now if you could just keep the cup holder closed (or leave it down unless you nees the get to the radio)!
  #15 (permalink)
Old 03-13-2009, 11:48 AM
2005josh2006 2005josh2006 is offline
Send a message via AIM to 2005josh2006
Yea looks clean to me!
  #16 (permalink)
Old 03-13-2009, 12:09 PM
19558077 19558077 is offline
looks good
  #17 (permalink)
Old 03-13-2009, 12:53 PM
BigSlick BigSlick is offline
I like it! but i too would be worried about the cupholder breaking.
  #18 (permalink)
Old 04-10-2009, 07:38 AM
tommpa tommpa is offline
Where did you mount the antennae? I was thinking about mounting it on the bed somewhere behind the cab.
  #19 (permalink)
Old 04-10-2009, 07:48 AM
peteoreo peteoreo is offline
What kind of antenna? I put a wilson mag mount on the roof run coax down rear door weather strip under seats to radio.
  #20 (permalink)
Old 04-10-2009, 08:00 AM
I have (forget name) but you need a mounting bracket bracket of some sort for it. It is a stick with wire wraps around the outside.
