Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
Old 02-09-2009, 12:08 AM
JBB66 JBB66 is offline
Vent in the back of the '08 Crew Cab Pickup...
Last week I had an audio shop in the area install JL Audio Sub and Amp. I noticed a couple days later between the truck bed and the cab there was something that was protruding out. Did some investigation and looks like it is some kind of vent (plastic). Damn installers are going to receive hell tomorrow.
But, how would I go about getting it pushed back in... any ideas. The installer must of push it out...
Any ideas would be appreciated. Thoroughly, irritated and pissed off about them not looking at what their pushing on and drilling. Also, right next to where the amp is installed .... there is a big gash in the carpet where they were going to install the amp on the wall, but decided that wasn't such a good idea.
You think I can get them to replace that carpet? And fix that vent protruding?
Jarrod B
Old 02-09-2009, 07:03 AM
rob05 rob05 is offline
You should be able to just stick your fingers through the holes in the vent and pull it back in. I have pushed it out a couple times. And yes, they shoudl replace the carpet if they cut it but ended up not using it.
Old 02-11-2009, 07:05 PM
DavidPhillips DavidPhillips is offline
Maybe get them to mount something free there where the carpet is cut. Is there a screw or something holding the vent out?
Old 02-11-2009, 07:07 PM
BLACK_PSTROKE BLACK_PSTROKE is offline
they should replace your carpet but they probably wont. good luck
Old 02-11-2009, 07:08 PM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
What vent?
Old 02-11-2009, 07:09 PM
If you look at the back of the cab you can see it.
Old 03-03-2009, 06:21 PM
MAttbracing MAttbracing is offline
Just push it back in they come out if you look at them sideways
i just put a sub in my crew cab tonight
Old 03-03-2009, 08:14 PM
how do you push it back it... my damn hands and arms too big! lol
Anyways, what kind of sub you put in?
If anyone is wondering what the JL Audio 13TW5 w/ JL Audio HD 750.1 sounds like.... it sounds awesome... no distortion... make your ears bleed haha.
Old 03-03-2009, 08:15 PM
To the previous posts... the fixed the carpet.
Old 03-04-2009, 06:21 PM
700okie 700okie is offline
The vent in the back of the cab is to let air out when you close the door, there should be like three flaps that open upward so that gravity pulls them back down closed. If they won't close maybe something in the way, try a broom handle or something to push them back closed. If they're working properly should see them open and drop back closed when you close the door quickly
