Instrument cluster swap - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 3 Old 03-25-2014, 07:03 AM Thread Starter
Hey all, was wondering if I can swap in a instrument cluster out of a lariat into an xlt?
Are the clusters plug and play?
Is the millage stored on the cluster in these trucks?
Will I get a temp/compass read out?
Just upgraded from a obs 7.3
Thanks!!
'086.4psd is offline
post #2 of 3 Old 03-26-2014, 09:38 AM
Snowboarder7710's Avatar
Quoted: 5 Post(s)
you wont get temp/compass through the cluster. the temp runs through the digital climate control on lariats. ive got an fx4 and added an auto dim mirror with temp and compass built in....its from an...**ahem**...chevy tahoe, but hey it fits perfectly and you cant tell its a gm part..unless you look at the temp sensor behind the grill.
not too sure about your other questions, but hopefully someone can chime in! but if its like the 04-08 f150s (im familiar with those), the mileage is stored in the cluster and they need to be programmed with your truck's "as built" data in order to operate your a/c and door chimes correctly.
Snowboarder7710 is offline
post #3 of 3 Old 03-30-2014, 06:20 AM
Powerstroke Techie
Mileage is stored in the cluster among other modules.
It will need to be programmed, but I'm not sure it will work properly since the XLT trucks have a button in the cluster to cycle through the information center.
The Lariat cluster(s) have a set of three buttons on the dash to do this. I am not sure if the wiring is there, but if it is you will need a new cluster surround and the buttons as well.
As for the compass and temperature you will likely need to add sensors for those.
You will also need a scanner that can do a parameter reset, and program keys, and have both your keys available when you swap it out, since part of the PATS functionality is in the IC.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
