Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Powerstroke Interior Discussion
Old 11-11-2008, 06:35 PM
Grewit93 Grewit93 is offline
New gauge lighting problem
Heres my problem... I have just installed my triple gauge set (trans, boost, pyro) on my 08 f-350, they are the autometer phantoms. So i have them wired up and they work great except the lighting. The lights work but they appear to loose power or something as they go up the pillar, for example the bottom gauge is bright, and they gradually get dimmer. I have all three light power wires wired together and then to the purple with gray stripe on the headlight switch as directed on the autometer website.
So why are the lights dimmer as they move up the pillar?
Any help would be great......
Old 11-11-2008, 06:38 PM
fordmugg fordmugg is offline
mine do the same thing ....not sure why it does it ...
Old 11-11-2008, 09:33 PM
beaky73 beaky73 is offline
never mind
Old 11-12-2008, 09:19 AM
Dusten Dusten is offline
Send a message via MSN to Dusten
are you tapping each wire into the next, or joining all three at the power source?
Old 11-12-2008, 03:16 PM
Wired the three together into one common wire and then tapped into the power source, just like the instructions say.
Do i need to run an individual light power from the source to each gauge light?
Old 11-12-2008, 06:49 PM
i would. tapping each wire into the next creates excess resistance across the taps, and the wires, this can cause a voltage drop, especially when dealing such a low voltage
