Sunroof switch - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 6 Old 02-18-2014, 10:22 AM Thread Starter
Quoted: 6 Post(s)
Sunroof switch
Can anyone tell or show me how to remove the lights and sunroof switch? I went to close the sunroof the other day and the switch pushed thru. I tried to remove the light housing and it started to break. Any help would be great!
joshua5438 is offline
post #2 of 6 Old 02-18-2014, 11:12 AM Thread Starter
Quoted: 6 Post(s)
Figured it out. That was way to hard to remove and the plastic is too easy to break. Does the black plastic inside the headliner mount to anything? It's just loose inside the headliner. Now..... Any suggestions on how to get the switch to stay in the housing since all the plastic clips broke? Don't want to spend $200 for a new one.
post #3 of 6 Old 02-24-2014, 09:36 AM
Unhappy Sunroof Switch Mount
I have the same problem. The small sunroof switch mount plastic side plates that screws to the console...the side plates have broken off which prevents the switch from being held in place. Ford and aftermarket parts are for the whole assembly at $235. All I need is the small sunroof switch housing that screws to the O/H assembly with two screws. Any idea where I could find a new one (outside of a used one at at boneyard which may experience the same brittle condition as my '08...don't know why a white color exterior with camel interior would get hot enough to cause the plastic to get brittle, but that's the way it seems.
spud1223
2008 F350 CC King Ranch
spud1223 is offline
post #4 of 6 Old 02-24-2014, 10:35 AM Thread Starter
Quoted: 6 Post(s)
I came up with a fix. It was hard to take pics of it but I will show you what I did. I added two plastic shims. The switch has a lip on each of the shorter ends that you can put shims on top of. Then the shims will actually hold the switch down once you install the white plastic assembly. I can get you the thickness of the shims but I did not measure the width or the length I cut them. You want the shims cut a little narrower that the short side of the switch. The length of the shim can be determined by placing the shim on the ledge of the switch and cutting it about 1/16" longer than the switch height. Hope this all makes since once you start looking at your pieces. Let me know if you need more info. The first pic shows the ledge on the switch.
post #5 of 6 Old 02-24-2014, 10:39 AM Thread Starter
Quoted: 6 Post(s)
Sunroof switch
This way has worked for a few days for me. It seems it should last longer than the factory cheap plastic since it is taking the stress off the tan plastic. All the stress is now on the ledge of the switch and the thick white plastic housing.
post #6 of 6 Old 02-25-2014, 08:46 AM
Thanks Joshua, I will give this a try. Beats trying to find a firm piece of styrofoam to place between the top of the switch and the white plastic housing.
spud1223 is offline
