Dome Lights won't work - Ford Powerstroke Diesel Forum
6.4 Powerstroke Interior Discussion
post #1 of 4 Old 02-13-2014, 03:33 PM Thread Starter
FlintRidgeFarmSN's Avatar
Been not working for several weeks now, won't even work when the dial for the dash brightness is turned all the way up. Map lights still work. I checked all the fuses today and none of them were out. Any help is greatly appreciated.
Thanks,
Sean
08 F250 Crew Cab SB 4wd
-SCT Livewire with RCD 450 Tune
-Diamond Eye DPF/CAT Delete
-4" MBRP DPF Back with 5" Tip
-Sinister EGR Delete
-35" Nitto Trail Grapplers
At some places they play football...at Alabama we live it.
FlintRidgeFarmSN is offline
post #2 of 4 Old 02-18-2014, 09:57 AM
Did you check the lamps? Since you have a crew cab, there are 2 dome lights, one each for the front and back of the cab. Each dome light enclosure has 3 lamps, one for the dome light, and 1 for each switched light, for a total of 3 lamps per light.
Check your lamps. The cover just pops off.
B. Adams is offline
post #3 of 4 Old 03-02-2014, 08:32 PM
Im having the same problem with mine. map lights work with the individual switches. Nothing comes on when I open the door or roll the switch on the dash. Fuses are good. Help is needed. All bulbs are fine.
LongWhiteBus is offline
post #4 of 4 Old 03-05-2014, 07:26 PM
It turned out the bulbs were in fact bad. If the dome ones dont work and the map ones do. Pull one out of the map and try in the dome.
